001287: Number of vertices must be -1 or greater than 4.
The Approximate number of vertices parameter has a value that is less than 0 or greater than 4. Valid values are -1 and greater than 4.
A value of -1 will show all the vertices in the footprint. The minimum value is 4, and the maximum value is 10,000.
Solution
Set the Approximate number of vertices value to -1 or greater than 4.
