001327: You must specify an Initialization Field for this Initialization Method.
You specified the Get seeds from field option for the Initialization Method parameter. You must also specify the name of the binary field identifying the seed features to use to grow clusters.
Solution
Specify a binary field (all values are either zero or one) that indicates which features will be used to grow clusters. Features with a value of 1 for this field will be used as seeds.
