001337: The maximum record length has been exceeded.
The record length is the number of bytes used to define all the fields in a table, not the number of bytes used to store the actual values.
Solution
Use a different format as output, such as a geodatabase.
Internally, some tools use temporary data that will fail if the size of the data exceeds 2 GB.
Learn more about attribute limitations
