001343: Project data source <value> in Task <value> is unsupported.
The tool uses unsupported data that cannot be converted to a supported format.
Solution
If you are creating a geoprocessing package, you must change the project data source to a supported type. If you are creating a geoprocessing service, you can register the project data in a data store. By doing so, the publishing process does not convert the data.
