001370: Failed to extract the service definition to the service's input folder. Common causes are a full disk on the server, the arcgis server account not having permissions, or a path that is too long. Please see the server's log for more details.
This error occurs after the service definition has been uploaded to the server. This can occur for following cases:
Creating the input folder for the service.
A failure may occur while creating the input folder. Possible causes include permission issues with the ArcGIS Server account, or a path that exceeds the operating system limit.
The server log reports folders the server could not create.
Copying the service definition (
.sd) to the input folder.Possible causes include not enough available space on disk for the service definition, or a path for the service definition that exceeds the operating system limit.
Extracting the service definition
Possible causes include not enough available space on disk for the extracted files, or a path for one of the extracted files that exceeds the operating system limit.
This server system tool is invoked by the publishing client when creating a service.
Solution
You will need to troubleshoot to determine the exact problem and what specific action to take. The server log should identify the path that is creating the problem.
Make sure that the ArcGIS Server account has the proper permissions to this directory.
Make sure that the disk has enough space for the service and data you are loading.
If your path exceeds the limit of the operating system, do one of the following:
Shorten the service name.
If publishing to a folder, shorten the folder's name, or publish to the root folder.
Change the physical path of the ArcGIS server's system directory so that it uses fewer characters. You will need administrative access to the server to do this.
Learn more about editing a server directory in ArcGIS Server Manager
