001419: Maximum Number of Variables parameter must be lowered to <value>.
The number of variables is small in relation to the number of features.
Solution
Reduce the value for Maximum Number of Variables, or use an Input Features dataset with more records. The number of records in Input Features should be larger than the number of variables specified. If you do have more records than variables, check to see if there is an active selection on the Input Features dataset.
