001487: Failed to update the published service with the server-side data location. Please see the server's log for more details.
Publishing can fail when server-side data registered on the server cannot be located.
Data stores can map an on-premises data path to an on-server data path (for example, c:\data to \\machine1\data). As part of publishing, a service that references on-premises data (for example, c:\data\usa) will be changed to reference the server data (for example, \\machine1\data\usa). If the server data is not found, this error occurs.
This error can also occur for data held in replicated enterprise geodatabases when the server-side replica is missing tables or feature classes.
Solution
View the server log to identify the expected data location that couldn’t be found. This data must be copied from on-premises to the server.
Ensure that the ArcGIS Server account has the proper permissions to this directory.
