001518: Failed to build tile cache for feature with OID = <value>.
When using a feature class to build cache for a specific area, generation of cache fails if the area represented by the feature with the object ID is outside the dataset or map extent for which cache is being built.
Solution
Ensure that the feature class contains features that lie within the extents of the dataset or the map document for which cache is being built.
