001536: The analysis options you selected require a minimum of <value> <value> to compute hot and cold spots.
Some of the options for the Incident Aggregation Method parameter require a minimum of 30 valid point or polygon features; others require a minimum of 60 valid point features. The table in How Optimized Hot Spot Analysis works outlines these requirements.
Solution
This tool will honor a selection set. If the Input Features value you specified has more than the minimum number of required features, check to see if there is an active selection that may be limiting the number of features being analyzed; otherwise, if you have less than 60 but more than 30 incidents, you can select an option for the Incident Aggregation Method parameter that only requires 30 incidents. Alternatively, perform your own aggregation prior to analysis.
