001544: No template map documents found in the specified directory.
The specified directory has no map documents (.mxd) or the directory does not exist.
Solution
Confirm the validity of the directory and ensure that the directory contains map documents (.mxd). You can ignore this warning when you only want to use MAP_ONLY and do not want to use template map documents.
