001571: The analysis options you selected require a minimum of <value> <value> with valid data in the analysis field in order to compute hot and cold spots.
There are fewer than 30 input features with valid data in the analysis field for analysis. Records with NULL values for the analysis field, for example, are skipped.
Solution
Check that the Input Features parameter value has a minimum of 30 features with valid geometry and number (non-NULL) values for the Analysis Field parameter value. Correct NULL values and missing geometry for a minimum of 30 features in order to continue with this analysis.
