001621: Invalid dataset name <value>. Tool requires relative paths.
A full path was used as the input parameter for this tool. The tool requires a relative path to the dataset.
Solution
Input dataset names for this parameter use paths relative to the input workspace. For example, if you use a SQL Server database connection as the workspace input, the relative path would be similar to <database>.<user>.<dataset>.
