001654: Cannot specify default value and clear value parameters simultaneously.
When clearing the default value of a field using the Assign Default To Field tool, you cannot specify a default value and clear the default value at the same time.
Solution
If you want to clear the default value of the field, leave the input default value empty. If you want to assign a default value to a field, uncheck the Clear Value check box or use FALSE if using Python.
