001837: Cannot validate datum transformation.
The datum provided cannot be validated based on the input and output spatial reference. This is an error if the Vertical parameter is not set (default), and a warning when Vertical is set.
Solution
Review the transformation used and replace it with the correct transformation or, in the case of vertical transformations, confirm that it is a correct transformation.
