001838: Cannot find proper vertical transformation. The Z values will be transformed with simple zero-level adjustment and unit conversion.
The Vertical parameter was enabled but the selected transformation is not applicable to the z-values. The z-values will be transformed with simple zero-level adjustment and unit conversion.
Solution
This is a warning. Confirm that this is a desired action. Regular data with z-values should use a combination of ellipsoidal and vertical transformations.
