001844: Invalid terminal configuration. Valid paths must be set if the number of terminals is 3 or 4.
When three or four terminals are defined, valid paths must be set to indicate which paths are valid for a resource to travel through.
Solution
Specify valid paths for the terminals defined in the Valid Path(s) parameter of the Add Terminal Configuration tool.
To learn more, see Create a terminal configuration.
