001985: The csv file has wrong columns. Check the header.
When importing rules, associations, circuit definitions, or subnetwork controllers, the input .csv file must contain specific fields and values.
Solution
Refer to the tool help to find the .csv requirements for the tool that you are trying to run. If there is an export tool that relates to the import tool you are using, you can use the output .csv file as a template.
