001993: Subtype code cannot exceed 1023 if the subtype is used in Utility Network.
When adding subtype codes to a dataset that participates in a utility network, the subtype code cannot exceed the value 1023. This restriction is due to a limitation of the internal storage mechanism used to store the values being used as a network attribute.
Solution
Choose a subtype code that is less than 1023.
