002029: The default path for the configuration is not valid.
When specifying the default path for the terminal configuration, the Default Path parameter value must match the name provided for an existing valid path in the terminal configuration.
Solution
Choose a valid path from the Default Path parameter options. These paths have been defined for the terminal configuration.
