002072: Rotate Tree Layout was not processed. There was no pivot junctions in the selected diagram features.
The Rotate Tree Layout cannot run without a diagram junction set as a pivot junction in the specified input diagram. Such a junction is the one around which the rotation will be processed.
Solution
Use the Set Pivot Junctions tool to set one or several junctions in your diagram as pivot junctions. If you have features selected in your diagram, you must specify one junction among this set of selected diagram features since the layout will apply to this selection set only.
