002102: The input layer uses one or more layer properties that are not supported in the scene layer.
Scene layers support a subset of layer properties available in ArcGIS Pro. This error occurs when the input layer contains any of the following:
Unsupported symbology properties
Unique value renderer with the length field, the area field, or multiple fields
Chart symbology
Dot density
Custom symbology using Arcade expressions
Procedural symbol layer
Dictionary symbology
Unsupported symbol properties
3D model markers that are not displayed in real-world units
Rotation using random orientation, an expression, or a field for Tilt (X) or Roll (Y)
Color using an expression
Size using an expression or random value
Unsupported layer properties
Multipatch layer whose height is derived from a ground surface
Transparency using an expression
Solution
Change the input layer properties to remove the unsupported elements.
