002104: There is no transformation available between the input and output coordinate systems.
There is no transformation path available between the datums for the input for the selected output coordinate systems. Remove the z-coordinate system. In this case, the vertical units of the scene layer package will be the same as the horizontal coordinate system's linear units.
Solution
Change the output coordinate system to one with a supported transformation path.
