002112: The root tile must overlap the data sufficiently for features to draw.
The root tile of the vector tiles must overlap a significant portion of the data for the features to draw.
Solution
Do one of the following:
  • Use the default tiling scheme suggested for the data. The default tiling scheme is suggested when the Package for ArcGIS Online | Bing Maps | Google Maps parameter is unchecked. This tiling scheme is created at C:\Users\[user_name]\AppData\Local\ESRI\Geoprocessing\[tiling_scheme_name].xml.
  • Update the tiling scheme so that its origin matches the top left extent of the data, and use scales in the tiling scheme file that will cover the data extent.
