002147: Feature-linked annotation may introduce editing limitations in your geodatabase.
Feature-linked annotation creates a relationship class between the annotation feature class and the base feature class. An ArcGIS Pro feature-linked annotation feature class will affect the ability to edit the base feature class in different versions of ArcGIS Desktop.
The following table describes how annotation is supported:
ArcGIS version
ArcGIS Desktop annotation
ArcGIS Pro annotation
ArcGIS Desktop
10.x
Full read, modify, and write access
Not supported. Any feature class linked to it, or in the same feature dataset, will be read-only.
ArcGIS Pro
1.x
Read-only access
ArcGIS Pro
2.x
Read-only access
Full read, modify, and write access.
Solution
Ensure that you understand where and how the data will be used, and make decisions accordingly.
If you need to continue to use the feature class in ArcGIS Desktop, make a copy of it and link the ArcGIS Pro feature-linked annotation to the copy.
