002534: The Enable Enterprise Geodatabase tool is only supported from ArcGIS Pro clients against SAP HANA databases.
The Enable Enterprise Geodatabase tool was run on an SAP HANA database connection from a client other than ArcGIS Pro.
Solution
To enable geodatabase functionality on an SAP HANA database, you must run the Enable Enterprise Geodatabase tool from ArcGIS Pro. It is also important to note that after an SAP HANA database has been enabled as a geodatabase, connections to this database will only be allowed from ArcGIS Pro and ArcGIS Server clients.
