002541: Duplicate attribute rule name was found.
An attribute rule of the same name already exists for the dataset. The name of an attribute rule must be unique for the dataset.
Solution
If you are trying to add a new attribute rule, use a different, unique name.
If you are importing attribute rules to a dataset, you must delete the existing rule with the same name before importing the new rule.
