002548: Address Locators: Locator <value> does not exist or is not supported.
The locator may be invalid for the following reasons:
  • The path is to a locator stored in a geodatabase.
  • The locator was created prior to ArcGIS Desktop 10.0.
  • The composite locator may contain a participating locator that is broken or invalid.
  • The locator on the server or portal is inaccessible or is not supported.
Solution
Do any of the following:
  • Select a locator that is stored in a file folder.
  • Select a locator that was created with ArcGIS Desktop 10.0 or later.
  • Create a new locator using ArcGIS Pro or ArcGIS Desktop 10.0 or later.
  • Verify that the locator is accessible on the network.
  • Verify that the service is started and running on the server.
  • Verify with an administrator or publisher on the Enterprise portal or ArcGIS Online portal that the locator is shared with you.
