002551: The field name defined in attribute rule is not available in class.
The attribute rule that you added or imported specifies a field that does not exist in the feature class.
Solution
Check the field names that are available for your dataset to see if one matches the field name specified in the attribute rule. If the field specified in the attribute rule does not exist, you must add the field to the dataset before you add the rule.
