002554: The dataset does not support attribute rules.
The dataset to which you tried to add or import attribute rules does not support attribute rules. Certain datasets are not supported for attribute rules, for example, the GDB_validation* error tables.
Solution
Use a different dataset on which to create an attribute rule. Refer to the Add Attribute Rule tool documentation for information about the data types that support attribute rules.
