002589: <value> is a reserved SQL keyword.
Specific words including SELECT, DELETE, and UPDATE are reserved and cannot be used for table, feature class, and field names. Attempting to use a reserved word as a table name will return an error. Using a reserved word as a field name will return an error indicating that the column name is invalid. Copying and pasting from a data source where the word is not reserved will add an underscore character to the end of any table or column name that is reserved in the file geodatabase.
The following are reserved keywords:
ADDALTERANDBETWEENBYCOLUMNCREATEDELETEDROPEXISTSFORFROMGROUPHAVINGININSERTINTOISLIKENOTNULLORORDERSELECTSETTABLEUPDATEVALUESWHERE
Some data sources have their own reserved words. For details, see Define fields in tables.
Solution
Use a different name and rerun the tool.
