002713: Attribute rule has invalid batch property.
The attribute rule type you're adding contains an invalid batch property.
Reference the Add Attribute Rule tool documentation to see if the rule type provided can be created with the batch parameter set as true or false.
Solution
Specify a valid value for the Batch parameter for the rule type.
