002717: Invalid Arcade expression
The expression provided contains invalid Arcade syntax. If you're importing attribute rules from a .csv file, the specific row number will be referenced.
You may encounter this error when executing the Import Attribute Rules or Add Attribute Rule tool.
Solution
Review the script expression and ensure that it meets Arcade syntax requirements.
See ArcGIS Arcade Structure and Logic for more information.
