002733: Country values have been selected from the reference data. The value chosen here will be used as a default for records that do not contain a value in the data. Change to <As defined in data> to remove the default value.
The value specified for Country or Region can act as a default value when building the locator if the country code value in the reference data is empty. If a default value should not be applied, set Country or Region to <As defined in data>, and any record without a country code value will be written to the locator as empty.
Solution
Do one of the following to resolve the warning:
  • Leave it as is and any missing country value in the data will be replaced by the value from the Country or Region parameter.
  • Choose <As defined in data> if a default value for the country code should not be applied if the country code value from the reference data is empty.
  • Unmap the country code field from the reference data in Field Mapping and select a country from the list to apply the country code to the entire reference dataset.
