002740: Incorrect input value for field value: value must be empty. <value>
When adding a new contingent value, you specified a field value when the field value should not be specified.
Solution
If the contingent value is of type any or null, you cannot specify a field value since it is assumed from the field type. If you chose the type any, you cannot specify a field value since the field value can be any value. If you chose the type null, the field value is set to null.
To specify a specific field value, you can use a coded value domain or range type of contingent value.
