002741: Incorrect input field value type: field value type must match selected field's domain type. <value>
When adding a new contingent value, you specified a field value type that does not match the properties of the field. For example, you cannot specify a coded value type if the field does not have a coded value domain assigned to it. You also cannot choose a range type if the field has a coded value domain assigned to it.
Solution
Review the properties of the field you selected and ensure that the domain assigned to the field matches the field value type that you are trying to use.
