002761: Version is protected. You can't write to a protected version if you are not the owner of the version.
When performing an edit operation on a protected version , an error is returned. The version access is set as a version property.
Inspect the current user and version to determine whether the data needs to be accessed as a different user, or a different version needs to be used to perform the edit operation.
For more information, see Manage branch versions and Manage traditional versions.
Solution
Ensure that the operation is completed as the owner of the version or a user with adequate permissions.
Optionally, adjust the version access property to public.
