002766: Custom elevation surface <value> not supported.
Custom elevation surfaces are not supported in ArcGIS Maps SDKs applications. Ground surface is the only supported surface.
Solution
Remove the custom elevation surface from the Contents pane. If multiple elevation sources are desired, add the elevation sources to the Ground surface. See Elevation surfaces for more information on working with sources and surfaces..
