002792: There are records selected from one or more of the reference data tables. The locator will be built with only the selected records.
There are features selected in the reference data assigned to the Primary Table(s) parameter in the Create Locator tool or the Input Features parameter in the Create Feature Locator tool.
There are records selected in the alternate name table or tables assigned to the Alternate Name Tables parameter in the Create Locator tool.
Solution
If you intended to build a locator using the selected features or records in the reference data, nothing is required.
If you intended to build a locator using all features and records in the reference data, clear the selection.
