002848: Datasets must be in a non-versioned state when using the only generate errors option.
When working with an enterprise geodatabase, the utility network must be in a nonversioned state to use the Enable Network Topology tool's Only generate errors parameter.
Solution
Ensure that the utility network is in a nonversioned state to use the Enable Network Topology tool's Only generate errors parameter.
