002934: Failed to publish web layer.
The web layer failed to publish for an unspecified reason. A common reason is that you do not have publishing privileges to the active portal.
Solution
In the View Details window, in the Parameters section, review the Publish Results parameter for information that may help you resolve the problem.
For example, if the problem is that you don't have publishing privileges, ask your portal administrator to change your permissions.
