002945: The length of the value exceeds that of the field.
The length of the coded values in the domain exceeds the maximum length of the field. For example, the field length is set to 4, but the coded value exceeds that limit.
Solution
If possible, increase the length of the field to accommodate the domain's coded values. Alternatively, modify the coded values to fall within the maximum length of the field.
