002951: Unable to process DisplayX/Y value in record ObjectID = <value> from the '<value>' input feature class.
The coordinate values in the DisplayX and DisplayY fields in the reference data exceed the possible minimum and maximum values defined in the coordinate system assigned to the reference data.
Solution
Verify that the coordinate values in the reference data field that was used to map the Display X and Display Y locator role fields are within the range of possible values for the coordinate system. Correct any values that are outside the possible range in the reference data.
Unassign the Display X and Display Y locator role fields if the values in the reference data are not necessary to build the locator.
