002958: Record ObjectID = <value> from the '<value>' input dataset has an unsupported value in the '<value>' field. Supported values: '<value>'.
The field in the reference data assigned to one or more of the following locator role fields contains an invalid value. The following values are valid for locator role fields:
  • Distance UnitKM, Kilometers, MI, Miles, M, and Meters
  • ParityNot applicable, NA, N/A, 0, D, Default, Z, Zero, Even, E, 1, Odd, O, 2, Mixed, M, Both, B, and 3.
  • Primary Name IndicatorP, Primary, T, True, Y, Yes, 1, A, Alternate, F, False, N, No, and 0.
  • Primary Street Name IndicatorP, Primary, T, True, Y, Yes, 1, A, Alternate, F, False, N, No, and 0.
  • SideL and R
Solution
Update the records in the reference data identified in the warning message with valid values, which are listed in the message.
