002969: Values for '<value>' = <value> are not found in input datasets. Locator will be built without those '<value>' values.
A Join ID value in the data does not have a corresponding attribute value in either primary or alternate roles.
Solution
Confirm that the Join ID is correct or that the corresponding records that should be associated with it have the correct value.
If the corresponding attribute field is mapped in the primary role, add the corresponding attribute value to the primary reference data for the Join ID value mentioned in the message.
If the corresponding attribute values should be taken from the alternate role, add the Join ID value mentioned in the message and its attribute value to the corresponding alternate name table.
