002975: <value> fields are mapped for the '<value>' role. '<value>' and '<value>' values have a higher priority and will be used in the locator. If these fields are empty, the '<value>' value will be used.
This warning occurs when all of the house number locator role fields have been mapped to build a locator with the Point Address, Parcel, or Alternate House Number locator role. The values in the reference data fields assigned to House Number From and House Number To role fields take precedence over the values in the House Number role field and are used when building the locator. If the House Number From and House Number To role fields are empty, the value in the House Number field is used.
This warning also occurs when all of the unit locator role fields have been mapped to build a locator with the Point Address locator role that supports subaddress. The values in the reference data fields assigned to Unit From and Unit To role fields take precedence over the values in the Unit role field and are used when building the locator. If the Unit From and Unit To role fields are empty, the value in the Unit field is used. For example, if the reference data field that is assigned to the Unit From role field has a value of 605, 605 is used as the Unit From and Unit To values.
Solution
Do one of the following to resolve the warning:
  • Do nothing.
  • Unassign the House Number or Unit locator role field in Field Mapping.
