002981: Value exceeds valid range of column.
A calculated value is not valid for an attribute field.
Solution
Review the value to ensure that it is compatible with the target field. Use a different field to update that is compatible with the value, or adjust the field properties to accommodate the value.
If the error was encountered when using remote data, review the database or ArcGIS Server logs for more specific information about the calculation error.
