002998: Failed to converge after reaching the maximum number of iterations.
The least squares adjustment failed to converge after performing the maximum number of iterations. The largest correction is still greater than the convergence tolerance.
Solution
Do one or both of the following:
Remove or fix outlier dimensions.
Increase the size of the convergence tolerance.
