003050: Dataset not found <value>.
An item you tried to import into the geodatabase belongs to a dataset that does not exist in the XML workspace document.
Solution
Confirm that the XML document used to import items is valid. If necessary, try generating a new XML workspace document to export items from the original dataset or geodatabase.
