003107: 'The '<value>' data field is mapped to more than one role field in '<value>' role.
An input data field is assigned to more than one locator role field for the current role, which can indicate a mistake in setting up field mapping in the Create Locator tool. However, there are cases when assigning the same reference data field to more than one locator role field is acceptable. For example, when assigning the same input data value to the House Number From and House Number To fields to indicate that a parcel feature does not have a range of house numbers associated with it.
Solution
If the reference data field was assigned to more than one locator role field by mistake, set the mapped field to <None>.
