003209: Spatial reference of the tiling scheme does not match the spatial reference of the feature dataset.
You chose a tiling scheme that doesn't match the spatial reference of the feature dataset where you are creating the output feature class.
Solution
Ensure that the spatial reference defined in the tiling scheme file matches the spatial reference of the feature dataset. Change either the tiling scheme file you're using or use a feature dataset with matching spatial reference. Alternatively, create the output feature class as a stand-alone geodatabase feature class or shapefile.
